01-26-2023
07:02
22:38
YojanaFitbit
01-26-2023
07:02
22:38
YojanaFitbit
I recently started using an inspire 3 and use it an alarm. It's nearly impossible to acknowledge it on the first try. Typically it takes 3 or 4 tries and then you get the annoying snoozes.
Has anyone found a way to adjust the sensitivity of the touch screen?
01-29-2023
19:56
06:36
01-29-2023
19:56
06:36
Hi there, @MIKEINALBANY. Welcome to the Community Forums. Thanks for stopping by and contacting our team to work on this issue with your alarms.
Sorry to hear you're still having this inconvenience. In case that you haven't do so, please restart your Fitbit: How do I restart my Fitbit device? Are you having issue with the screen using any other feature besides the alarms?
