05-01-2023 14:28
05-01-2023 14:28
Bought an Inspire 3 and planned to use my new Mac to set it up and track my progress.
Finding out that the only way is a smartphone.
Anyone have any workarounds? Is jailbreaking allowed?
Really want to keep this thing, but don't see a way through.
Best Answer05-02-2023 02:07
05-02-2023 02:07
Hi, @fitsh1te, welcome, in order to set up you will need to install the Fitbit app on your device Fitbit Supported Devices provides the details.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer05-02-2023 04:15
05-02-2023 04:15
@fitsh1te Many Mac users also own iPads. If your iPad supports iPadOS 15 or newer, you can use your iPad. The App Store says it's for iPhones, but you can put it on your iPad. I have it on mine.
Laurie | Maryland
Best Answer05-03-2023 00:56
05-03-2023 00:56
What if I dont have an iPad, then what do I do?
Best Answer05-03-2023 02:44
05-03-2023 02:44
Hello @unidentifiable and welcome to the Community. I'm sorry, but you need a compatible Android or Apple smartphone/tablet.
Laurie | Maryland
Best Answer05-03-2023 17:23
05-03-2023 17:23
Thats ok, I've got a family chromebook, I was just wondering
Best Answer05-04-2023 14:16 - edited 05-05-2023 04:22
@unidentifiable I’m sorry, but you can’t setup or sync with a Chromebook, despite that fact that Google created Chrome OS and owns Fitbit.
Laurie | Maryland
Best Answer05-04-2023 17:41
05-04-2023 17:41
Actually, Ive set up my account on a chromebook, and it works perfectly fine
05-05-2023 04:16
05-05-2023 04:16
@unidentifiable Please, please, please share what you did with the rest of us! This might help some users. The official word has always been that Fitbit isn't compatible.
Laurie | Maryland
