12-14-2024 02:14
12-14-2024 02:14
For the last few weeks, when I enter my weight is only shows in lbs. My weight settings are set in stones.
12-15-2024 15:45
12-15-2024 15:45
@Yogacombat , a warm welcome to the Community! Thank you for your message and information.
Our team is aware of the issue with the stones units. They are looking into this and will work on a solution.
We suggest you to follow this thread where all updates will be posted. https://community.fitbit.com/t5/Android-App/Manual-weight-entry-not-accepting-stones/m-p/5696054/hig...
Hopefully this will get solved soon.
