Hi @Tooker002 you can see the battery strength as low, medium or high. On Android, just tap the icon upper left of the dashboard and it takes you to another screen. There you tap on your device, going to another screen that tells you the current power left in the battery.
Best AnswerAs with every other lousy change to the home screen, it is NO LONGER an option to see a numerical value/percentage of battery life in the screen. It is still available on the device, but is very small, so difficult for many to read.
Hi @Marel66 when I put my Inspire 3 on the charger, the screen is larger with the percentage showing on it.
Best AnswerYes. it is. I do not want to go find my charger and connect it every time I wish to check battery status though, that’s cumbersome. Also only works while at home with charger. Seeing it on the home screen, as it was before the update, was much more convenient.
