Worked fine, now won't track much sleep time
So it started out real good and now it doesn't track but 2-3 hours of my sleep. Any ideas as to why?
2 REPLIES 2
Hi, @D3vilDog74, welcome to the community, you may find this article of interest How do I track my sleep with my Fitbit device? , you will note your body needs to be "at rest" about an hour before it records you being asleep. For some restless sleepers, this causes a problem. Allowing you have looked into the advice in my link and your problem persists may I suggest you get a friend or family member to try it for a few nights, you might just be very restless.
I hope this helps.
Cheers
Gr4ndp4 | UK
It's good to see you in the community for the first time @D3vilDog74.
Thanks for sharing the inconvenience with us regarding your Inspire 3. If you are still experiencing the issue with it, and in addition to the tips suggested kindly by @Gr4ndp4, I'd recommend:
Try to restart your device. Please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
