12-17-2023 16:37
12-17-2023 16:37
Hi
What extra large band can I buy for the inspire 3 please? The one it comes with is too small for my wrist.
Thanks
Best Answer12-17-2023 16:45
12-17-2023 16:45
Hi @Starry513 the bands are either small or large. You might find an elastic type band on Etsy or Amazon, but often they don't fit, as they aren't original.
See this sizing chart. click to view
Best Answer12-19-2023 13:31
12-19-2023 13:31
Hi
Thanks gor the answer, does it automatically come with a small or large band?
I'm wearing it on the last two rungs that it came with.
Thanks!
Best Answer12-19-2023 14:54
12-19-2023 14:54
The Inspire 3 comes with both bands, so you can choose. If you need something larger, there might be a seller on Amazon with a band extender. Sometimes you can find them there for the different styles of Fitbit.
Best Answer12-26-2023 07:44
12-26-2023 07:44
Thank you, I will have to see what I can find.
