01-16-2023 16:40
01-16-2023 16:40
when i'm vertically scrolling through the various screens on my inspire 3, i find it difficult to look at the hourly activity and other screens below that as a single view of just that info. the inspire 2 "snapped" to each view, so i could kind of flick from one to the next. this one just kind of scrolls smoothly sometimes not all the way to the next info, sometime completely past it. hopefully i'm making this clear. thanks!
01-20-2023 06:34
01-20-2023 06:34
Hi, @rudyb, welcome, I see the issue you describe, you might be able to get the result you want with practice otherwise it seems to me this would require a software change.
You can put forward feature suggestions here, it's worth using the search bar to see if others have put forward something that merits your vote. Failing that posting your own detailed idea is a simple process.
Cheers
Gr4ndp4 | UK
Best Answer01-20-2023 06:34
01-20-2023 06:34
Cheers
Gr4ndp4 | UK
Best Answer01-20-2023 11:41
01-20-2023 11:41
thank you!
