Inspire HR lilac and rose gold band accessory
Does anyone have the lilac Inspire HR and the rose gold band?  I'm wondering if the two colors go well together....since I love both colors...wasn't sure if they clashed...I need to replace my Alta HR...it just died last night....so I'm shopping and not sure what to get.
3 REPLIES 3
@SLC323 Welcome to the Community.
Thank you for your inquiry. Not sure if these two colors will combine but hopefully someone in the Community will be able to share a picture of this. Also if you have a brick and mortar store you could go check if they have the Inspire HR in these colors. Remember that if you purchase from the Fitbit store you have 45 days to return your purchase as described here.
Finally what happened to your Alta HR? Have you tried any troubleshoots?
Let me know how it goes.
Alvaro | Community Moderator
I have been noticing some oddness with my Alta HR, for example I would have to tap very hard and several times before the silent alarm  was turned off.
Then the green light that would indicate that it’s alive no longer displayed. The battery was at least half full at the time.
Now when I plug it in, it takes several tries to get the ‘buzz’ that means it’s connected and I only see an exclamation mark on the display....after a couple mins I now see a charging indicator.
Hi
I have been wondering the same thing.
I have just come across a review on gadgetsandwearables.com for the Inspire HR and she has pictures of the lilac one with a gold and silver band - albeit the gold is more gold than rose gold.
Let me know what you think!
