05-03-2019 15:14 - last edited on 05-04-2019 11:07 by YojanaFitbit
Only had the inspireHR less than a month and it will not charge. I tried everything it said to do on the held site but to no avail .Only charged it 3 times total. Don’t know if it is the charger or the Fitbit . But now the Fitbit is dead as a door nail . I am leaning toward the charger.
09-30-2020 09:31
09-30-2020 09:31
MaryLol, did your replacement work? My Inspire HR stopped charging the same month the 1-year warranty expired. They sent a replacement, but the replacement doesn't charge either!
10-15-2020 04:25
10-15-2020 04:25
I've had my fitbit less than two months and it won't turn on or charge, this was a gift. I've tried everything for it to work and yet it sits unused. Worthless.
10-23-2020 07:04
10-23-2020 07:04
I am having the same problem only had my inspire since June, I have tried the suggested fixes and it worked once but now it has stopped charging again. Help!!!!
10-23-2020 07:08
10-23-2020 07:08
Good morning,
I can't get my inspire to work and I have sent several message indicating as much, I have tried the fixes and it worked only once, now its not working at all. Please can I at least get a response from Fitbit. Really disappointed in the lack of support
10-26-2020 05:33
10-26-2020 05:33
10-27-2020 06:05
10-27-2020 06:05
How can the"best answer"even be considered an answer? Who decided this was answered?
01-25-2021 10:21
01-25-2021 10:21
Adding a reply since this seems to be top hit on Google....
My device also was very picky about charging, so I used a small screwdriver to ensure there was no debris on the contacts. (A a paper clip would work fine, too). Brushed away with an old toothbrush, then cleaned with rubbing alcohol. Was 100% charged from dead in less than an hour.
05-20-2021 10:53
05-20-2021 10:53
I have the same problem. Fitbit Inspire HQ will not charge. Please email a fix for me. I'm out of the country and need my watch!!
05-20-2021 10:55
05-20-2021 10:55
Fitbit Inspire HR - sorry. Will not charge. Traveling and need my watch!!
05-20-2021 12:28
05-20-2021 12:28
HI, my problem was solved when Fitbit replaced my charger. Turns out it was defective
05-20-2021 16:00
05-20-2021 16:00
05-20-2021 16:01
05-20-2021 16:01
06-15-2021 05:24
06-15-2021 05:24
3rd Fitbit Inspire now - and after my last charge, it will not now not show anything on the face!!! Is the life on these only a year?!?!?!? It's literally like clockwork to the day my last one had problems in June of 2020??? What is the problem Fitbit?!?!?
09-24-2022 16:57
09-24-2022 16:57
My fitbit is also not working when the charger removed from watch it is not working
09-25-2022 07:00
09-25-2022 07:00
not only will I never EVER buy a Fitbit again after going through 5 of them in 5 years, but I'll do my best in recommending that NO ONE ever buy one of them.
total scam and inferior quality
12-23-2022 17:48
12-23-2022 17:48
I took a pin and cleaned out the 2 contact points on my Fitbit Inspire HR, moistened a Q-tip with alcohol and wiped the contact points on the charger and on the fitbit. Dried them off with tissue and reconnected - it worked immediately and started charging.
