01-21-2019 15:21
01-21-2019 15:21
My Ionic hasn't synced in almost a week, when I plug it into the computer it says there is an internal error. I have tried everything posted in other threads, and nothing has worked.
Also, when I go on a run, it shows my stats when I'm finished, but hasn't been saving them. When I go back through my workouts the runs are missing?
Best Answer01-21-2019 21:47
01-21-2019 21:47
@GlacierBlueGirl wrote:My Ionic hasn't synced in almost a week, when I plug it into the computer it says there is an internal error. I have tried everything posted in other threads, and nothing has worked.
Yeah that sounds screwy. If you have already tried everything would contact Tech Support. If they cannot get your device to work properly they should replace it. Many have reported getting replacement devices by contacting them directly. Unfortunately no one on this Help Forum has any authority -> they just refer there anyways.
