Active minutes & calories not syncing to iPad
Active minutes and calories are higher on Ionic and syncing to iPad app.
everything else is syncing correctly. Restarted Ionic and the app but still wrong.
1 REPLY 1
It's great to see you around @AndyAttwood. Thanks for the troubleshooting that you've tried.
Active minutes and calories burned are calculated using your heart rate information since your Ionic tracks it. In this case, I would like you to double check that you're following this tips to have accurate heart rate data.
If you continue to experience the same, please reply to the following questions:
- How many calories burned and active minutes more are you receiving?
- Is the data the same that you're seeing in your Ionic and app?
Keep me posted.
