05-26-2020
09:24
13:45
AndreaFitbit
05-26-2020
09:24
13:45
AndreaFitbit
Since the latest OS update, I noticed that the following setting are no longer accessible (greyed out):
Brightness (set to DIM)
Do Not Disturb
Screen Wake
Anyone else?
Moderator Edit: updated subject for clarity.
03-28-2021 06:12
03-28-2021 06:12
Thanks, Deepak! It took about 45 minutes of trying to fix it myself and then Googling solutions but your suggestion WORKED. I can now see the screen to track outdoor runs. Thank you!
04-10-2021 15:49
04-10-2021 15:49
I now have this problem. Updated phone app, rebooted Ionic. Sleep Mide, Do not Disturb and Screen Brightness still greyed out. What can I do?
16:29
13:13
SilviaFitbit
04-10-2021
16:29
13:13
SilviaFitbit
When updating I had to go back to reset my watch back to default settings. The only thing that fixed it. Try that !! Good luck.
Moderator Edit: Personal info removed
04-12-2021 00:00
04-12-2021 00:00
not sure if you resolved this issue but i fixed it myself. nothing here helped me.
Since basically every setting was greyed-out i changed my left control shortcut to quick settings and changed it from there
Best Answer01-11-2023 19:48
01-11-2023 19:48
Thanks! Your suggestion worked! Thanks
Best Answer07-04-2023 09:00
07-04-2023 09:00
I contacted supported who were very helpful. I had the same problem of having most options greyed out.
This was the solution to my issue, which must have been set inadvertently…
From the initial clock screen, swipe left. Turn OFF “Do not disturb”, which is the MOON icon.
That worked for me. 👍
Best Answer07-04-2023 09:04
07-04-2023 09:04
Correction to above comment.
“Do not disturb” is the icon that looks like a do not enter sign. Sleep mode is the moon. Swiping left from the initial clock face and Turning off one or both of these should solve the gray out problem.
Best Answer07-04-2023 09:13
07-04-2023 09:13
Correction to above commentS LOL
Swipe right, not left. 😂
Best Answer07-06-2023 13:46
07-06-2023 13:46
Hi everyone!
Currently there is a Voluntary Safety Recall of Fitbit Ionic Smartwatches and won't be more updates. For more information, please visit our web page at help.fitbit.com/ionic.
I wanted to let you know that I'm going to close this thread to keep the community organized and prevent any confusion if you have questions regarding a different device please post your query on the correct board.
