Just wondering if the Fitbit ionic or any other Fitbit has any alarm app that would be able to wake up a person that is completely deaf in one ear. They sleep mainly on there good ear and the majority of the time sleep through there alarms, so some sort of vibrations may be best.
Best AnswerThe Ionic uses vibration to indicate an alarm is triggered. I would think that may meet the criteria since it vibrates on the wrist. Now, whether the vibration is intense enough to rouse the sleeper is another issue to consider.
Best AnswerTom, the alarm on the Ionic has a vibration feature. I would check the settings on the watch itself to make sure the vibration settings are turned on. There are two options for vibration levels, normal and strong. I hope this helps.
