10-27-2018 07:29
10-27-2018 07:29
I've had my Ionic almost a year and recently noticed the low battery notifications are coming at the last minute, too late to charge it if it's right before bed and I want to track my sleep. Does anyone know if there is any way to change the battery percentage when it will notify you? Last night, it was down to 23% when the notification finally came through and it was dead by 7am. I also have noticed if the battery is low during sleep, it reverts to the old basic sleep details. I love my current watch face but unfortunately, it doesn't have the battery % right on the face. May be time to change that!!
10-27-2018 07:54
10-27-2018 07:54
Unfortunately, @CMichelle, there is no way to change that default. When i scroll up a screen to the Stats, I always glance at the battery level at the top of the screen - if I notice it around 40% or below, I put it on the charger next chance I get. Some functions, such as the GPS, are disabled when the battery level gets down to 25%, so I never let it go that low.
10-27-2018 16:57
10-27-2018 16:57
@CMichelle ate you reffering to the low battery warning on the ionic? This comes at 30%
Or are you reffering to the email notice? This comes with the first sync after the battery gets below 30%. If background sync is turned off, turning on background sync could get you the email sooner
10-28-2018 06:59
10-28-2018 06:59
My all day sync is on and I'm not getting notified via the app on my phone or as a notification on my watch until I'm down to 22-23%. Weirdly enough, I just charged my Ionic yesterday up to 99% and by this morning, it was down to 22% again - that's happened a few times and I have no idea how to tell what is draining my battery so fast? This probably happens every 3rd or 4th charge. I'm also only getting maybe 2-3 good days of life, when it actually holds a charge rather than the 4 - 5 days I was getting on my Blaze. I don't use the GPS so guess I'm a little disappointed it isn't doing better than this and yesterday was just normal usage, no exercises, just a day out and about shopping and housework. Very frustrating!
10-28-2018 07:07
10-28-2018 07:07
FWIW, @CMichelle, my Ionic rapidly charges to the 99% status, and then it takes it over 1/2 hour longer go reach 100%. I always leave it on the charger until it reaches 100%, to ensure it is fully charged. Once mine is fully charged, it typically lasts 5 days before it needs charging again.
10-28-2018 15:01
10-28-2018 15:01
Turn off all day sync..notifications as well. I get 5 days with those settings off.
