02-02-2018 16:50
02-02-2018 16:50
I was planning on getting a new Note 8 tomorrow but after seeing it wasn't on the list of supported phones (neither is the Note 4 I have now) I'm having second thoughts. I really don't want my Ionic to work even less than it already does.Can someone let me know if the GPS, Pandora and Strava features work with their Note 8?
thanks!
07:13
08:01
02-11-2018
07:13
08:01
@Lisas1202 Welcome to the Fitbit family! Thanks for your interest for Ionic. I was checking the list of supported devices and the Galaxy Note 4 and Galaxy Note 8.0 are both listed as supported. You should not have any trouble using Ionic features with those phones.
Are you experiencing any trouble with it?
Keep me posted! ![]()
Best Answer03-16-2018 07:23
03-16-2018 07:23
I've got a Note 8 and it works with my Ionic. I can't speak for Strava or Pandora as I don't use those features, though.
03-16-2018 07:43
03-16-2018 07:43
My LGV10 worked mostly fine w/ my Ionic. Occasionally had to reconnect the two, but otherwise i received all notifications and everything worked mostly as it should - except for music library. Recently my LG died and I got a new Samsung Note 8. My Ionic has NEVER synced notifications with the Note 8 - no texts, phone calls, FB, etc. I have to manually sync my fitness info 2-3 times daily, even with the "all day sync" selected (and it takes 8-10 attempts each time). Same with sleep tracking. I'm really disappointed that my Ionic is now nothing more than an over priced watch. I'm also disappointed that Fitbit is putting out a newer Smartwatch (Versa) instead of maintaining or improving/correcting performance on their current products. This will be my first and last Fitbit product. Which is sad because I waited almost a year just to buy Fitbits first smartwatch as my first smartwatch because I thought they would do it right...
Best Answer03-16-2018 08:01
03-16-2018 08:01
Another Note 8 and Ionic user here. I have not had any issues
Best Answer03-16-2018 08:25
03-16-2018 08:25
I have a Samsung Galaxy S8 Active, which came out a month before the Note 8, and my Ionic works fine with it.
Best Answer03-16-2018 08:45
03-16-2018 08:45
Another note 8 user and no problems here either.
Best Answer03-16-2018 16:56
03-16-2018 16:56
I ended up getting the Note 8 and haven't had any problems at all 🙂
Best Answer03-19-2018 18:59
03-19-2018 18:59
Does the media player work for you guys? The ionic does not see the media playing on my phone. I've tried connecting to the Bluetooth classic mode, but that doesn't work either.
Best Answer03-20-2018 03:34
03-20-2018 03:34
03-20-2018 04:07
03-20-2018 04:07
Another Note 8 guy here. 🙂
I don't have issues for now except for the crappy way of transfering music which you have to try several times to succeed. 🙂
Best Answer04-16-2019 11:07
04-16-2019 11:07
Interesting. I've spent 3 days trying to get deezer or Pandora to sync with my ionic from my note 8. After day 2 of crappy customer support they just told me that the note 8 has not been tested & is not supported by the ionic.
Best Answer07-28-2020 13:56
07-28-2020 13:56
My wife was told that the Ionic is not compatible with Samsung Note 8....funny thing is we both have the Ionic and we BOTH HAVE the Note 8 and she just recently started having sync issues ...kept calling tech support and 1st 3 techs made no mention of compatibility...
I've never had a problem with my Ionic and Note 8....Fitbit is lying
09-26-2020 10:04
09-26-2020 10:04
Right, this is important. My ionic has always worked great with my note 8 until the latest firmware update. Now @fitbitsupport are telling me it is not compatible so they cannot help with the synching issues that have just started to happen after their recommended firmware update. Rediculous.
