10-28-2017 10:27 - edited 10-29-2017 06:51
Is anyone happy with their Ionic? Is yours fully working and syncing? It seems most discussions here are about the problems, but looking at different stores online the reviews are still mostly positive. I can't tell if the one I have is just never going to work or it's a firmware issue that could be fixed. Right now I'm leaning towards this one is never going to work, but then I'm not sure if I should get a new one or not.
05-01-2020 19:35
05-01-2020 19:35
I have been very happy with my Ionic since I bought it last July, until tonight. The display went blank, it won’t charge and it won’t connect/sync. It seems quite dead. Upsetting to say the least.
iPhone 8s
05-01-2020 19:37
05-01-2020 19:37
iPhone 8 Plus, iOS 13.3.1
05-01-2020 19:38 - last edited on 09-21-2020 20:12 by LiliyaFitbit
Mine was put in the box and is sitting in a draw. Couldn’t sync with my iPhone. Heart rate recording was off. Mileage was off.
Best Answer05-01-2020 19:43
05-01-2020 19:43
Best Answer05-02-2020 02:07 - edited 05-03-2020 13:36
Yes. I'm happy with mine. I've had the Charge, Surge and now the Ionic. The older two had their problems, and these were solved with the Ionic.
This isn't the most expensive watch around, yet, for the price point, it serves its purpose really well. It's comfortable, doesn't fall off, can go swimming with me, has plenty of clock faces, the GPS and HR can be exported and spliced with my bike rides.
The only thing that could be better would be a connection to my bikes cadence/speed sensor. I'm guessing that this will come in a future iteration and if I was desperate for it now, then I'd go spend three to four times the money on a different product. The sad thing is that it's technically possible to do this with the fitbit ionic right now if someone could code it into the firmware.
Yes, I'm happy with my fitbit and I enjoy wearing and using it.
Best Answer05-03-2020 11:52 - last edited on 11-02-2020 10:20 by LiliyaFitbit
It worked! Thank you!
Sent from my iPad
Best Answer05-03-2020 12:50
05-03-2020 12:50
Best Answer05-03-2020 13:27
05-03-2020 13:27
Same here , I'm getting frustrated
Best Answer05-03-2020 13:30
05-03-2020 13:30
This work for me before
Best Answer09-21-2020 09:39
09-21-2020 09:39
Nope....not happy lasted just about 1 month past 2 years. I never abused it and always wiped it down after exercise and it just died after a week of missing pixels. Its my 3rd fitbit and I won't be buying another.
Best Answer11-01-2020 12:14
11-01-2020 12:14
No. It locks up and needs to be reset and software re-installed every few months. It sucks.
Best Answer11-16-2020 16:28
11-16-2020 16:28
my ionic stopped syncing with my iPhone 6. I got a new iPhone 11. It works a little better but I still have issues with it syncing occasionally.
