10-14-2019 20:21 - edited 10-14-2019 20:56
Is there anybody who can say are the Fitbit Ionic problems matter of hardware or of software?
I mean disappearing of sensors information, no working hart rate, no steps counter, battery draining, ets.
Best Answer10-15-2019 03:38
10-15-2019 03:38
It seems to be software related. Unfortunately they are not acknowledging the issues and may not put out an update that will fix the broken Ionics.
Best Answer10-17-2019 08:03
10-17-2019 08:03
I think that it's a combination of hardware and software.
I owned 2 Ionics. They both broke. Defective touchscreen both times.
The bottom line here is whether the problem is hardware or software--there is no fix in sight and FITBIT support seems completely disinterested.
Customer care is not a priority for them.
Best Answer10-17-2019 08:59
10-17-2019 08:59
@IONICOWNER you have several responses in your own thread - click to go there - where a moderator has contacted you with some questions. You should go there and let him assist you.
