10-02-2017 15:05
10-02-2017 15:05
Earlier I went on a 40 min walk. I didn't activate the run feature as I wanted to try the auto-detect run feature . After my walk, my steps/calories were counted but my walk was not tracked . My understating was that the walk will be auto tracked after a period of 15 mins but that didn't happen- any reason why?
10-02-2017 15:59 - edited 10-02-2017 15:59
The feature is "Auto Run" not "Auto Walk". Do not get the "Auto Run" feature confused with the "Auto Exercise Recognition" feature:
Auto Run - Your Fitbit tracker will automatically begin tracking an exercise run after a couple of minutes of running. GPS will be used.
Auto Exercise Recognition - Your Ionic will auto-recognize exercises and add them to your Exercise History list
10-02-2017 16:10
10-02-2017 16:10
Earlier I went on a 40 min walk. I didn't activate the run feature...
FYI, no reason to choose the "Run" activity when going for a walk. If you don't have the "Walk" activity, edit the Exercise Shortcuts setting on the Fitbit web portal to add it to your watch.
10-02-2017 21:07
10-02-2017 21:07
10-02-2017 21:39 - edited 10-02-2017 21:40
I just activate auto and it recognize a walk after 15 minutes
10-02-2017 21:42
10-08-2017 08:31
10-08-2017 08:31
how do I add walk to my fitbit ionic
10-08-2017 09:00
10-08-2017 09:00
10-08-2017 09:22 - edited 10-08-2017 09:28
Or: you select auto select in Fitbit App,
and select walk as an excersize, Maybe you have to delete another one.
the Ionic autoselect my walk, run and bike automaticly
10-08-2017 09:26 - edited 10-08-2017 09:27
Hi Sue
in the Fitbit app you tap Account > Ionic > Exercise short cuts.
the ionic can only store 7 exercise types so you may have to remove one before adding walk. You can do that by tapping Edit in the top right. Once added you can re order them as well by dragging the exercises up and down the list.
on my Ionic I have walk as the first exercise and then on my watch I can press the bottom right button which takes me straight to the walk exercise.
10-09-2017 09:12
10-09-2017 09:12
Thanks for the help, how do I get walk to show first?
10-18-2017 19:11
10-18-2017 19:11
Thanks so much!! I was trying for days to figure that out.
10-18-2017 19:12
10-18-2017 19:12
To the right of the exercise there are 3 little lines. Drag those lines up or down and it’ll move the exercise.
10-23-2017 17:11
10-23-2017 17:11
My auto run feature will not stay turned off when I turn it off. How do I get it to turn off ? I don't want it to do that at all.
06-12-2019 05:20
06-12-2019 05:20
Did you get a response to how to make the Auto Detect shut off? I have mine set to ignore and it is still auto detecting.
06-12-2019 05:35
06-12-2019 05:35
