01-23-2018 20:17 - edited 02-07-2018 16:23
My ionic was reseted, after that , the battery is draining quickly, in 24 hous.
Same suggestions?
Moderator Edit: Updated Subject for Clarity
07-02-2018
14:57
08:37
07-02-2018
14:57
08:37
@weasellyone @msjillian Thanks for your replies and for sharing your experience on this thread.
I'm glad to hear that customer support sent you replacements. They should arrive soon. Please feel free to follow these replacement set up steps for you to not loose any of your previous data.
@jjoonathan I hope you're doing well. Thanks for sharing your experience with customer support. That's unfortunate. By any chance, have you contacted them again to let them know that your Ionic is still draining the battery? You should use your open case to inform them; maybe they can check again?
@Samurai67 Welcome to the Fitbit Community! Thanks for also sharing your experience with Ionic's battery on this thread.
Firstly, please check these helpful article providing some tips you can use to maximize the battery on your Ionic.
If the battery keeps draining quickly after trying that; let me know!
Keep me posted! ![]()
07-29-2018 08:46
07-29-2018 08:46
Battery not charging at all now. Was charging like every 5 or 6 days then every 2 days then not even 24 hrs and now nothing..
Best Answer07-29-2018 17:21
07-29-2018 17:21
Hi Dansha,
tou should contact fitbit support and they will explain to to you what you need to do ... If your battery completely died then everything is clear but if still work a bit you will need to follow few steps that fitbit will be able to monitoring your watch. If battery is not good anymore you will probably get new watch like me.
Wish you all the Best,Tomaz
13:43
08:36
07-30-2018
13:43
08:36
@Dansha Welcome to the Fitbit family! Thanks for reporting the situation you are experiencing with Ionic's battery not charging.
Have you tried performing a restart on your watch? This has helped other users in the past.
Also, please take a look at these solutions for batteries that are not charging. Try them out to check if that sorts this out.
If non of that works, please follow @Samurai67's suggestion about contacting customer support for them to monitor your watch.
Hope this helps. Keep me posted! ![]()
10-14-2018 16:47
10-14-2018 16:47
@SantiR like the other ones in this thread, I'm also suffering from battery issues after the last update. One thing I don't understand is why it was working ok prior to update and suddenly went that bad and a replacement is necessary instead of rolling back the update? I reset the device, did a factory reset and battery lasts for 1,5days without using GPS/Music/Always connected Off.
Like the other guy from Vietnam, I live outside United States, what turn things complicated for replacements.
You guys have to sort this out, otherwise international customers will be wary of buying your devices.
10-15-2018 01:24
10-15-2018 01:24
Hello,
My FitBit Ionic is also dying very quickly. I've done the following items:
-Restarting
-un-pair from phone then do a "Factory Reset"
It drains 50% overnight, when I'm at 80% and use GPS it does not last long.
Can someone please help me? I've had the watch less than a year.
Really frustrating how can a 300€ plus item have this behavior
Best Answer10-16-2018 12:10
10-16-2018 12:10
I was thinking about getting an Ionic after receiving a 25% discount (only $179.95) from Fitbit for my Blaze (purchased June 2017) and replacement Blaze (replaced March 2018) batteries and sensors dying, but am now reconsidering when reading this thread!
18:51
08:37
10-17-2018
18:51
08:37
Hi @Avioesemusicas @tagoredinis @Ron_A, welcome to the Fitbit Community.
Thanks for following our recommendations to resolve the battery issue before getting in touch. @Avioesemusicas I created a case with Customer Support for you. Please check out your inbox on the next days. They will let you know how to proceed as soon as possible.
@tagoredinis It seems that you contacted our team already. I'm sure they will provide a response soon.
@Ron_A I'm sorry to hear about the difficulties you experienced. Our team is constantly working to improve the Fitbit experience and appreciate all the feedback. If you decide to get the Fitbit Ionic, we will be happy to continue with the process. If you would like to compare the different features of the Fitbit products please visit this site.
Please let us know if you have any questions.
Best Answer10-18-2018 07:59
10-18-2018 07:59
Got my Ionic as a Christmas gift. Like others expressed, had a battery life of 4-5 days and all of sudden Iucky if I get 2 daysmax. Tried resetting; pairing/pairing; turning of GPS and notifications, etc.
So, is this dying battery a common issue for the Ionic? Feel bad about having recommended this tracker to friends...
Best Answer10-18-2018 08:46
10-18-2018 08:46
I just deleted my 25% offer from Fitbit. As good as the prices seem, I don't want to waste another dime on their products at this time. When my Blaze is 100% dead, I will switch back to my Zip to track steps and buy a smart watch in the future once they have worked out more of the bugs.
Best Answer10-20-2018 14:31
10-20-2018 14:31
My Fitbit ionic is less than a year old. I was getting 5-7 days of battery life which was awesome. Suddenly this week I have to charge daily. Nevermind the fact that my notifications will not ever display properly and rarely ever work at all.
Extremely unhappy about this purchase.
16:13
08:37
10-21-2018
16:13
08:37
@SunsetRunner @dysmoy It's great to see you in the Fitbit Community.
Experiencing difficulties with the battery of the Fitbit Ionic is not a common issue. In order to further evaluate your situation, please let me know which mobile device are you using the sync your Fitbit Ionic.
@SunsetRunner Please be so kind to confirm that you have followed our recommendations posted above,
I'll be waiting for your response.
Best Answer10-22-2018 04:24
10-22-2018 04:24
I use a Samsung Android phone to sync my Ionic. Unfortunately, my Ionic went totally dead this weekend. I have it on the charger right nbow to see if it will come back to life. In the meantime, I back using my old Charge 2.
Best Answer10-22-2018 17:14
10-22-2018 17:14
I have Samsung Note 8 Android.
Best Answer10-23-2018 09:19 - edited 11-14-2025 08:38
Thanks for getting back guys @SunsetRunner and @dysmoy! I'd recommend checking these tips to maximize the battery on Ionic. There are several factors that may be draining your battery. Usage of features and apps is the most common one.
Additionally, I'd recommend taking a look at the article: Why isn't my battery charging?
If your phone is running the Android 8 operating system, you may see a notification letting you know the Fitbit app is using battery resources. For more information, see Why is the Fitbit app sending a notification to my Android phone?
10-23-2018 16:21 - edited 10-23-2018 16:22
I was using minimum number of functions, having turned off GPS and notifications of any sort. Turned off the widget and all day syncing as well.
Anyway, it's moot. The Ionic died a quick death (less than 10 months). I have been trying to charge it back to life for two days with no success.
Am looking to see if my gifter still has the receipt for this fitbit.
In the meantime, my old Charge 2 is still working, while I try to research what other waterproof fitness/activity tracker to consider next.
david
Best Answer10-26-2018 12:40 - edited 11-14-2025 08:38
Thanks for getting back @dysmoy! Since you've exhausted all the tips and recommendations provided, I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
Best Answer10-28-2018 07:12
10-28-2018 07:12
I am having the same problem, but my Ionic is draining as fast as 4 hours. Help.
Best Answer10-29-2018 07:03 - edited 11-14-2025 08:38
Welcome on board @Macoy21, it's nice to see you here! I've seen that you got in touch with our Customer Support Team yesterday. Please keep an eye on your inbox for next steps on this matter.
Let me know if I can be of further help.
11-09-2018 03:27
11-09-2018 03:27
Hey, i had the same problem, I indeed did change the clock face, is this what is affecting the battery?? At the min I´m unable to use my Fitbit which is very frustrating 😞
