04-22-2019 11:53
04-22-2019 11:53
I put my watch on this morning from the charger at 6am. It was 100% charged. It is now 2:30pm and it is dead. It's not even a full year old yet. Close but not yet. What gives? Can the battery be replaced?
On a side note as a Conga player, it counts as a step every time I hit my drums....
Best Answer04-22-2019 23:26
04-22-2019 23:26
Hi @Leemoeller Try restarting it several times andnif that doesnt help try a factory reset. If you are still having battery problems please come back here (quickly before the year is up!)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
