01-04-2019 12:53
01-04-2019 12:53
Hi,
My Ionic has suddenly started to drain a lot of battery.
I have tried to restart the Ionic couple if tines.
I have always keept it updated to latest software and firmware version.
I have shutdown phone notice functionallity to save battery.
Nothing helps, got at the best 1.5 days battery time.
What shall I do?
01-04-2019 18:34
01-04-2019 18:34
Do you get a lot of notifications? Ther have been reports of bad battery life after the recent update where the watch lights up every time a notification is received if you get a lot. Id suggest you contact Support in any case (link in my signature)
Helen | Western Australia
01-05-2019 03:49
01-05-2019 03:49
Not so many.
I have turned that function off but the battery time is not improving.
01-05-2019 09:30
01-05-2019 09:30
I've been having the same problem for a while now, @Lars_A. Another user told me you must charge up to 100% (not 99%) every time or it will drain more quickly, for some unknown reason. I find that does help sometimes but lately, I'm lucky to get 1.5 - 3 days of battery life when I got almost 5 with my Blaze before. I don't use music or GPS, only notifications, reminders from various apps and Exercise modes to track my workouts. I changed my screen brightness to Dim and my Display Awake is middle of the road at 20 seconds.
Any other suggestions to improve battery life?
01-05-2019 11:42
01-05-2019 11:42
I have also seen difference between 99 and 100 procent with about 0.5 day extra 1.5 days instead of 1 day
