06-03-2020
11:28
20:01
RicardoFitbit
06-03-2020
11:28
20:01
RicardoFitbit
I’ve been using my fit bit ionic a lot recently and it used to be able to survive 4/5 days without charging, now it barely can do a day. Wondering if anyone else is having the same issue and is there a fix?
06-05-2020 20:00
06-05-2020 20:00
Hi @peryfabowain123, welcome to the Community Forums!
Thanks for bringing this to my attention. Let me share with you that the battery of our Ionic was designed to last 5 days, but this also depends on how frequently you use all the features of your device. That said, I recommend you charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much.
After following the above information, please check this help article for more tips and recommendations. This article includes as restart process that will refresh the device's performance.
Keep me posted, I’ll be right here if you need anything else.
