04-01-2018 23:51
04-01-2018 23:51
Hi All,
Looking for the best headphones to use to cinnect to the Ionic. Habe read a heap about the issues but keen for some feedback on what people are using with no dramas. Currently looling at the Jabra Sport Pace, Plantronics Back Beat Fit and the Fitbit flyer. Any feedback qould be greatly appreciated. Already had a failed attempt with a cheap set so dont want to have any issues this time.
Cheers
04-01-2018 23:57
04-01-2018 23:57
Hi @JimC2018,
Welcome to the forums. Of the three you mentioned, I have and use the Fitbit Flyers. They actually sound better than any other bluetooth headsets I've used. And they can simultaneously connect to two devices, so I can toggle between using them for music with the Ionic and my phone for calls.
04-02-2018 00:22
04-02-2018 00:22
I have the same opinion of @WavyDavey: Fitbit Flyers are really good.
04-02-2018 17:16
04-02-2018 17:16
I've tried several Bluetooth headphones and Bluetooth speakers, iIhaven't found any that the ionic will not connect.
Yes the flyer with its several types of ear pieces I find comfortable and sound great .
04-02-2018 17:53
04-02-2018 17:53
Thanks for the feedback.
I haven't had any issues with the Ionic connecting with speaker and headphones, however have had some issues with the audio quality. So was just looking for some feedback from other user experiences with specific headphones.
06-29-2018 11:31
06-29-2018 11:31
I am using TaoTronics Active Noise Cancelling Headphone. It is one of the best noise cancelling headphones under $100 I have ever used. It is very comfortable to wear and can stream music over 25 hours.
