03-29-2018 16:25
03-29-2018 16:25
Long story short, dog was on the bad end of a skunk and the scent transferred to my watch in the cleaning chaos. Rubber is pretty porous and I've had quite the difficulty cleaning it. I've used an enzyme buster that does the trick for fabric based items. Any suggestions to getting these bands smelling fresh?
Best Answer03-30-2018 15:36
03-30-2018 15:36
If it's that bad then just buy a new one if your so convinced that it's impossible to get the smell off
Best Answer03-29-2018 16:40
03-29-2018 16:40
Hi @Bornee,
I don't know the best way, and that doesn't seem covered by Fitbit's cleaning instructions. 🙂
If nothing works, at least the band on the Ionic is replaceable!
03-30-2018 14:03
03-30-2018 14:03
Warm water with a ton of liquid soap and brush it? Baby wipes? Maybe wipe it and then spray a ton of perfume on it.. it's not rocket science bro
Best Answer03-30-2018 14:29
03-30-2018 14:29
Using it sparingly, you could try rubbing alcohol. I say use it sparingly only because it could dry out the band.
one cruise ship at a time!
Best Answer03-30-2018 15:19
03-30-2018 15:19
bless your naive little brain, you're lucky skunks aren't native to the UK.
03-30-2018 15:36
