So im wondering if its possible to get a longer notification with calls. When i had the Blaze, it would vibrate till an action was taken, i.e. call, reject or missed. It would also stay on the screen. But with the ionic, its like a txt. 1 vibrate and a quick incoming, thats if i even get a notification. Can this be fixed?
06:55
08:03
02-08-2018
06:55
08:03
@PinoyDDragon Welcome to the Fitbit family! Thanks for your suggestion and for sharing your experience on this thread regarding the vibration of the call notifications on Ionic. Great suggestion by the way.
I was making some research on the Feature Suggestions Board and was able to find a couple of ideas that may be of your interest:
Those ideas are asking for pretty much the same as you are! I'd recommend voting for those ideas and leaving a comment. The votes and comments the better!
Also, if you'd like to suggest a different idea, feel free to search for similar existing ideas or add your original one.
Thanks again for your suggestion. See you around! ![]()
