09-29-2017 17:57
09-29-2017 17:57
When someone calls my ionic just says unknown caller instead of the name.
09-30-2017 12:51
09-30-2017 12:51
A warm welcome to the Community @Mets86! I would like you to confirm that the person that's calling it's saved in your phone's contacts. Also, if you go to the phone's settings; just you've allowed the permissions to enable your contacts.
Additionally, make you you have the latest version of the app 2.58 for Android and 2.40.1 for iOS.
Hope this helps!
Best Answer09-30-2017 13:05
10-03-2017 10:02
10-03-2017 10:02
Hey @Jorkal! Thanks for sharing the pictures about how the notifications show in Fitbit Ionic.
Hope I can continue seeing you around. ![]()
Best Answer12-29-2017 08:21
12-29-2017 08:21
I'm having the same problem.. I did update my contacts to give app permission to my Ionic & then restarted it but still showing unkown for callers that are in my contacts but when they text me it shows their name (weird). Phone is completely up to date (Samung Galaxy 7).
01-04-2018 10:45
01-04-2018 10:45
It's great to have you here @Tiffersn84! Thanks for the troubleshooting that you've done. I've shared your post with our Support team, keep an eye in your inbox.
Hope this helps! ![]()
Best Answer01-09-2018 17:45
01-09-2018 17:45
I am having the same problem. Did anyone find a solution?
01-12-2018 16:23
01-12-2018 16:23
A warm welcome to the Community @Mredding19! I would like you to confirm you've properly followed the procedure posted above.
Hope this helps! Keep me posted.
Best Answer02-21-2018 09:06
02-21-2018 09:06
Me to same problem.
02-22-2018 14:29
02-22-2018 14:29
A warm welcome to the Community @Merc0723! I would like you to make sure that the person who is calling should be in your contacts and shouldn't be someone that you may have blocked (depends on the service provider).
Also, sometimes it has to be with the selection of contacts, contacts display accounts, some say Phone and others Google Contact or it can use both. You may want to change the person from phone contact to a Google contact and the name should show up on the tracker.
Hope this helps!
Best Answer03-21-2018 15:45
03-21-2018 15:45
Does it work now?
Best Answer03-21-2018 16:14
03-21-2018 16:14
08-28-2018 13:09
08-28-2018 13:09
I have google pixel and having same issue. I tried re-installing app and tried turning permission on and off and still doesn't show name on the call, I can see name when I get message though.
08-30-2018 13:55
08-30-2018 13:55
I have the pixel as well same issue
08-31-2018 03:30
08-31-2018 03:30
I have the pixel 2xl and have the same problem. permission has been granted and app and watch restarted several times but no change.
08-31-2018 04:21
08-31-2018 04:21
Best Answer09-02-2018 13:30
09-02-2018 13:30
Thanks Mate,
It's already on.
Best Answer09-02-2018 19:09
09-02-2018 19:09
I confirm the issue on Pixel 2 XL with Pie. All permission granted.
09-20-2018 22:34
09-20-2018 22:34
No it didn't help. I already have notifications on.
Best Answer05-15-2019 13:48
05-15-2019 13:48
Hi,
I don't know if this problem was resolved but I had the same problem after the Android 9.0 update.
To fix:
Fitbit app > Notification > Calls (Turn OFF and ON)
This worked for me. Hope this fixes for everyone.
