12-30-2017 10:34 - edited 12-30-2017 10:39
Hello,
My first ionic had a problem with general notifications (it was the last firmware).
This ionic died suddenly (battery seems to have died).
Fitbit has sent me a new watch.
I use android fitbit app.
Now, i receive all general notifications (sms, app notifications...). But, for call notifications i don't receive them.
I tried several tests:
- if I turn off the watch and restart it, the call notifications are received... Several minutes, and after I, again, don't receive them. When I receive them, it is sometimes with a delay (like someone described in this forum).
- I tried to made a fresh reinstall. Call notifications were received during several hours... And again I started to mot receive them.
- i tried to remove all third party apps and clock face... No result.
- I tried to uncheck and check again call notifications in fitbit app
So, am I alone ? Should I contact fitbit to get a new watch ? (The third)
Or, is it something that is reported ? (I did not see topic on this)
Best Answer01-02-2018 09:18
01-02-2018 09:18
I have managed to set up and get text notifications, however the call notifications do not work. I have checked that the app permissions allow access to the phone and that notifications are turned on but it doesn't work.
My wife also has an ionic and she is experiencing the same issue, can get text notifications but not calls. We have Samsung S7 and S8 phones.
Anybody else had this issue or have a solution?
01-02-2018 16:14
01-02-2018 16:14
Ok
I ve found the problem
In the app, go to the ionic and select notifications
Here you can see an option to activate the fitbit widget that help if you have problems with notifications.
Activate it.
It should work after that...
As i had reinstalled the app, this option had been disactivated on my phone.
(I have a s7 edge)
Hope it can solve your problem like it solved mine
Best Answer01-03-2018 00:17
01-03-2018 00:17
I had tested this already and this option was set to on. I even tried re.oving the from the account and the whole app and reinstalling, but still no luck. Thanks for trying to help though.
Best Answer01-03-2018 04:19
01-03-2018 04:19
@Oneminutewonder wrote:I had tested this already and this option was set to on. I even tried re.oving the from the account and the whole app and reinstalling, but still no luck. Thanks for trying to help though.
You are right
I was thinking it was solved, until I receive a call this morning... And no notification on the watch
Best Answer01-03-2018 17:54 - edited 01-03-2018 17:57
I have a galaxy s7 and can receive calls notifications but no text message notifications.
Best Answer01-03-2018 18:07
01-03-2018 18:07
Have you all gone into App Notifications as well
Best Answer01-03-2018 21:13
01-03-2018 21:13
Best Answer01-03-2018 21:19
01-03-2018 21:19
Yes I've tried everything! I even called customer service and they weren't able to help either they basically told me to wait for the next Fitbit update ughhhh
Best Answer01-05-2018 23:57
01-05-2018 23:57
Maybe linked to the phone.
I have a s7 edge...
Best Answer01-08-2018 23:48
01-08-2018 23:48
I think I have found the cause of the problem
In parameters, activate "Nearby device scanning" (connections / more connection settings"
It solved my problem and since yesterday evening I get call notifications
If it works yet during the next 48hours, I would update this post and mark it as solution.
Best Answer01-09-2018 00:05
01-09-2018 00:05
Thanks for this, however n checking my settings this option was already activated.
Best Answer01-13-2018 00:22
01-13-2018 00:22
Again
You're right
It has not solved the problem
Best Answer01-13-2018 02:55 - edited 01-13-2018 02:57
Here is a link in another topic searching for answers as well. My large posting was yesterday... with Images...
Also an overlooked option on the Ionic itself From the clock face screen swipe left to right and you get this.
Also in settings..
Best Answer03-28-2018 11:11
03-28-2018 11:11
I went into the Apps and selected to receive notifications from Verizon Caller ID. Now receiving phone call notifications on my Ionic.
