02-06-2019
19:19
18:29
SilviaFitbit
02-06-2019
19:19
18:29
SilviaFitbit
Calorie burn and swimming stroke are inaccurate. If I swim the same distance 3 minutes slower, the calorie burn shows more calories used if I had swam faster for the same distance. It also shows that I swim backstroke when I haven’t swam that stroke more than 20 yards in four years.
02-07-2019 18:36 - edited 02-07-2019 18:39
A warm welcome to the Community @CliffSwimmer! I appreciate the details that you've mentioned. I would like you to restart your Ionic and then confirm that you've properly set the swim settings.
If after checking the above, you're still seeing inaccurate information. Please provide me with a screenshot of what you're getting.
Keep me posted.
02-08-2019
13:37
11:00
SilviaFitbit
02-08-2019
13:37
11:00
SilviaFitbit
There are no adjustments for either issue that I can find.
Moderator edit: Removed personal info
Best Answer02-11-2019 11:02
02-11-2019 11:02
Thank you @CliffSwimmer! I've shared your post with our Support team, they will continue assisting you on this matter.
Best Answer04-23-2019 13:45
04-23-2019 13:45
Calorie burn accuracy is a real issue as I have my Ionic tied to my WW app and it's so far off on calories it's messing with my daily food allowance. I swam 1850 yards (just over mile) in 54 minutes (3"/100) and it showed I only burned 320 calories.
Went to Gentle Yoga where heart rate monitor works, nothing more aggressive than a lot of stretching, and it shows 360 calories! Hello!!!!!!!!!!!!
Calorie burn should be simple-- Yards (which it knows)/ Time (which it knows) and my weight (which it knows). Using this website and putting in the same it comes up with over 600 calories and 3 or 4 other sites using the same 3 data points come between 500-700 so think this is right.
http://www.swimmingcalculator.com/swim_calories_calculator.php
Is there a way to fix this or do I have to make up a fake exercise and add in the missing calories, essentially rendering the Fitbit as useful as a handbrake on a canoe. Help!
Best Answer04-25-2019 11:50 - edited 04-25-2019 11:52
It's great to see you around @donnaconner. Thanks for the details that you've shared and the swimming calculator that you provided too.
Is there a way to fix this or do I have to make up a fake exercise. If there are some inconsistencies in your swim data and it can be caused by any of the following:
Also, I would like you to make sure that you've entered the pool length to have an accurate measurement. You can learn more about it by checking this article: How do I track my swims with my Fitbit device?.
Best Answer04-26-2019 21:36
04-26-2019 21:36
Thanks for replying but don't think we've solved the problem:
You completed only a few laps - NOPE, swim 1650 yards
You stopped to rest multiple times or in the middle of the pool-NOPE, only rest :30 every 100 yawards
You stopped to rest for longer than 60 seconds after completing a pool length-NOPE
You changed your stroke type midway through a length-NOPE
You swam with a kickboard or without using your arms-NOPE
You swam less than the minimum duration needed for your swim to be automatically recognized-NOPE
Also, I would like you to make sure that you've entered the pool length to have an accurate measurement-YEP
So why do you show 1650+ in under an hour ( which is high intensitity) as only burning 320 calories/ less than seated Yoga.
used a friends Garmin and it came to 620 calories by triangulating my weight/distance/time.
Solutions pls
Best Answer04-27-2019 16:40
04-27-2019 16:40
Thanks for getting back @donnaconner. I appreciate the time that you took to reply to each question. I've shared your post with our Support team, they will continue assisting you on this matter.
