Can I Control Ionic's GPS for Battery Life Saving?
Using a Fitbit Ionic with a Galaxy S6. Does the GPS on an Ionic work similar to a cell phone where I can turn it off to conserve battery, or am I always being tracked? The only GPS setting I've been able to find is in the Exercise app.
Moderator Edit: Updated Subject for Clarity
8 REPLIES 8
You wont be tracked always. GPS is enabled when you choose appropriate workouts that make sense for a GPS context such as run or bike.
And then begin said workout on the exercise app?
@cwilcox08 Welcome to the Fitbit Community! Yes, you can begin the workout from the exercise app. You can also begin it if the GPS has not connected, once signal is available it will connect.
There is also an option on your online dashboard's Ionic settings in which you can control how the GPS works. Check the picture below:
GPS ControlGPS Control
It is very complete so you can have full control over GPS! Also, check this help article about GPS for more details about this feature.
Hope this helps. Let me know how it goes! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
I am sorry but I do not see this anywhere in the app or on the watch. Can you specify where this is?
You have to do it from a computer
Try the link below, then select the Ionic on the left.
https://www.fitbit.com/settings/profile
Work out...eat... sleep...repeat!
Dave | California
Does the GPS turn off automatically when an exercise is completed? I have noticed a quick battery drain after I've finished a run.
@tenno78 Welcome to the Fitbit forums! Thanks for posting the experience you have had with battery after finishing a GPS activity and for your inquiry about this.
Yes, GPS will turn off once the activity is finished on your watch. The battery drain corresponds to the GPS usage as this feature will drain battery quicker on your watch. The battery on your watch lasts up to 5 days. GPS battery lasts up to 10 hours. However, there are other factors that will drain battery quicker; check them out here.
Hope this helps. Keep me posted! Smiley Happy
