04-30-2018 08:38 - edited 04-30-2018 10:34
I have my Ionic to give a cue each mile when I run. It does show this but I need to be looking at the watch to notice it. On my Surge I had a vibration that let me know I reached each mile. Is it possible to set a vibration or get a sound to do this on the Ionic ? If so how?
TIA.
Best Answer04-30-2018 11:07
04-30-2018 11:07
I get a vibration on my auto-cues for runs.
I don't recall seeing a setting to enable/disable the cue vibration; it's just the way it works for me.
Best Answer04-30-2018 11:25
04-30-2018 11:25
Thanks for your message - I don't see how to make a vibration or noise though. The FB manuals leave a lot to be desired.
Best Answer04-30-2018 11:31
04-30-2018 11:31
There's certainly no method to get an audio cue as the Ionic does not have a speaker.
Have you adjusted the vibration intensity on the on-Ionic Settings?
Best Answer04-30-2018 11:36
04-30-2018 11:36
Yes, it is on strong
Best Answer04-30-2018 12:52
04-30-2018 12:52
It would be nice if it could give an Audio cue over bluetooth to the headphones, even better voice prompts like on the app!
Best Answer04-30-2018 13:20
04-30-2018 13:20
If you're getting vibrations for other notifications, it may be best to contact customer support for more focused troubleshooting.
