12-11-2019 21:42
12-11-2019 21:42
Hello!
I will not have access to any computer in two weeks. Lookt after a charger that you put in the plug but found none. I wonder if I can charge it via mobile charger. On the charger it says 50-60Hz 0.5 A, output 9.0 V, 1.67 A or 5.0 V, 2.0 A. (Samsung Fast Carger) or 50-60Hz 250m A, output 5.0 = 1000 mA .
12-12-2019 01:21
12-12-2019 01:21
Yes, you should be fine. I've used nothing but wall chargers since I started with fitbits 6 years ago.
Fitbit say: "Plug the charging cable into a USB port on your computer, a UL-certified USB wall charger, or another low-energy device"
from: https://help.fitbit.com/articles/en_US/Help_article/1799/
The "UL-certified" is just to make sure that the wall charger is safe. In Europe it has the "CE" safety mark instead of UL. They just want you to avoid use of cheap, potentially unsafe, chargers.
12-12-2019 08:19
12-12-2019 08:19
Thank you for a quick response. 😊
