10-03-2017
13:39
10:42
DavideFitbit
10-03-2017
13:39
10:42
DavideFitbit
Hi , I did my first 10k run using the ionic today and noticed that you can only display one stat at a time. Is there a way you can configure the screen to show ( for example ) heart rate and distance on the same screen? currently you have to keep tapping the screen and scroll through the different stats until you get the one you want and that can get very frustrating during a tough run!
Moderator edit: format
Best Answer10-03-2017 13:45
10-03-2017 13:45
When you go into the exercise app and choose the workout you want (lets say 'Walk'), there should be a little gear icon in the top left corner of the screen. If you tap that, go down to the third menu item ('Customize Stats') tap that, and then you should see Top Stat, Middle Stat, and if you scroll down Bottom Stat. Top and Bottom Stat can be changed to show what you want it to, where as the Middle stat will always rotate through all of them.
I hope that was explained well enough and that it helps.
10-03-2017 13:45
10-03-2017 13:45
10-03-2017 14:42
10-03-2017 14:42
Hi hs100789
Thanks very much! your solution worked!
