01-21-2018 08:08
01-21-2018 08:08
Just gotten a new Ionic after replacing my dying surge finally, All i am wondering is can it be charged using a USB wall charger or do I need to charge it off a computer every time? I know this has been an issue for other fitbits in the past. Thanks.
01-21-2018 08:16
01-21-2018 08:16
I have Ionic which I charge using a wall charger with no issues.
01-21-2018 09:26
01-21-2018 09:26
I've always charged all of my fitbits including the Ionic with a wall charger, never had a single issue with battery performance.
01-21-2018 09:51
01-21-2018 09:51
USB is a standard for all kinds of connections.
But all use the same wires in the cable for the same things.
So if you charge it via PC or via wallsocket, it uses the same wires.
The only real difference is if you use a data cable and also want to use the data connection, that will not be possible with a wall socket
But even the datacable can be used with a wall socket.
So no worry's just charge
