11-07-2018 04:13
11-07-2018 04:13
Hi I cannot pair my ionic with my Huawei mate 20 Pro. When I turn on the Bluetooth my phone will not pick up my watch so I unable to get notifications. I guess my phone is not supported and if so any idea if my mate 20 Pro will be supported in the near future?
Thanks.
11-07-2018 04:41
11-07-2018 04:41
Hi, @Tfh1974, there are known issues connecting Fitbits (and actually many other Bluetooth devices) with Huawei Lite phones. Please see this help article for Fitbit's statement on this. I believe that this is because the Huawei Lite phones have a different Bluetooth protocol.
If the Mate 20 Pro handles Bluetooth similarly to the Lite versions, then your phone is unlikely to work with your Fitbit. I believe this is a relatively new phone, so I don't know whether its BT is like the Lite versions or not.
11-07-2018 04:43
11-07-2018 04:43
11-07-2018 05:04
11-07-2018 05:04
Hi, @Tfh1974, that's excellent! If you can share the steps you took to fix the issue, then it might help other users.
11-07-2018 05:55
11-07-2018 05:55
12-19-2018 00:53
12-19-2018 00:53
Hello
i am new to here. and i have exact same issue to synch with Huawei Mate 20 Pro
can you share more the detail with me please ?
12-19-2018 00:59
12-19-2018 00:59
12-20-2018 19:36
12-20-2018 19:36
A warm welcome to the Community @SunsetRunner! Currently, Huawei Mate 20 Pro isn't listed as a compatible device. You may want to try this syncing troubleshooting but I can't confirm it will always sync because it hasn't been tested by Fitbit.
Thanks for sharing your experience @Tfh1974.
12-25-2018 11:25
12-25-2018 11:25
I have th huawei mate 20 Pro and it works fine with the versa, you just have to go into the phone manager and turn off the automatic battery manger for the fit bit app
12-27-2018 03:03 - edited 12-27-2018 03:05
Any idea when Fitbit will get their act together on adding Huawei Mate 20 Pro to the sync list???
It has been one of the most advertised Android phones for some time yet still there are sync issues?
I have a Fitbit Ionic which was fine with my previous Google phone but appears to be pretty useless with the Huawei mate 20 pro
01-14-2019 06:26
01-14-2019 06:26
You would think with the amount of enquirers fit bit would get this fixed with Huawei
01-14-2019 07:32
01-14-2019 07:32
A warm welcome to the Community @Rossjm93 and @Ellisn1966. It's great to see you around @KellieCollins. Sorry for the delay on my response.
I was checking the list of supported devices and the Huawei Mate Pro 20 isn't on the list. This might be the reason why it's not syncing as expected. You can try the syncing troubleshooting but I can't confirm that this will sync smoothly as it hasn't been tested by Fitbit yet.
Any tips that you can share with other users are more than welcome.
01-14-2019 07:36
01-14-2019 07:36
01-14-2019 07:38
01-14-2019 07:38
I have had my mate20pro and versa for over a month and have not experienced any problems. Have you tried turning off the power manager for the fitbit app?
01-14-2019 07:40
01-14-2019 07:40
01-14-2019 07:57
01-14-2019 07:57
Go into huawei phone manager app, click battery then app launch. Find the fitbit app and deselect it (manage manually) . Otherwise huawei detects it is consuming power and tries to shut it down. I read this on the italien thread and it worked for me.
01-14-2019
16:28
17:43
SilviaFitbit
01-14-2019
16:28
17:43
SilviaFitbit
Great seems to have fixed it but time will tell
Kind Regards,
Moderator edit: Removed personal information
01-18-2019 09:40
01-18-2019 09:40
I can't help notice the core question has not been answered. Can you confirm whether Fitbit is actually working to ensure compatability with the Mate 20 Pro, which, as has been pointed out, is a massive seller? Because if not, this Charge 3 Special Edition is getting returned.
01-18-2019 14:27
01-18-2019 14:27
01-18-2019 15:05 - edited 01-18-2019 15:05
Hey @KellieCollins. Thanks for getting back. I'm glad to hear that's working for you.
Thanks for sharing what you found on the Italian Community and worked for your @Rossjm93.
Welcome to the Community @SunsetRunner. I don't have any specific information about what are the new mobile devices that Fitbit is currently testing and adding them to the compatible list. However, my recommendation will be to keep an eye on the list.
