11-11-2017
02:54
08:27
11-11-2017
02:54
08:27
Hi,
I tried setting up the Ionic on an iPad Pro, but it could not find the wifi, in fact no wifi where listed at all.
When I did the same on my older iPad Air, it found the wifi and I could connect the fitbit to wifi easily.
I noticed in an old article that the iPad Pro was not certified yet.
Not sure why this should be an issue but there you go.
Has anyone been able to use the fitbit with an iPad Pro and connect to wifi?
11-13-2017 08:26
11-13-2017 08:26
It's nice to see you here @froden, how's everything going?
Check if the iPad Pro you belong is listed in our Fitbit supported devices. See my image below:
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
If you're still unable to set up, try these troubleshooting steps:
11-16-2017 05:55
11-16-2017 05:55
Hi
the latest version of the app which just came out solved the iPad Pro problem, it seems.
Best Answer11-16-2017 06:47 - edited 05-19-2025 10:06
Great news @SunsetRunner!
I'm glad to hear that your iPad is working with your Ionic. Thanks for sharing what worked for you.
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community. You can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
I'll be around. Happy stepping!
Best Answer12-15-2017 08:52
12-15-2017 08:52
Neither my phone (LG V20) nor my tablet (iPad Pro 10.5) are on Fitbit’s supported device list. I’ve been getting by with a Samsung phone but this lag in device support is making me consider leaving the platform, even though I’ve been a Fitbit owner and user since 2009. I’m certainly not ordering the Ionic, which I admire from a features standpoint but without support for my devices, there’s no point.
Pondering my options until the new year.
