03-18-2018 13:51
03-18-2018 13:51
My cardio fitness score yesterday was about 55 but now it has suddenly dropped to a score of 30.
Help me, please.
08-01-2019 07:38
08-01-2019 07:38
I started using the gps on my versa more too and it’s dropped quite a few points as well, and I’m more fit than ever.
11-24-2019 06:34
11-24-2019 06:34
I had the same issue. If you have any poorly tracked runs you can delete them and your cardio score will bounce up. I ran for a good 30 minutes and my GPS thought I did half a km which massively skewed numbers.
01-05-2020 04:27 - edited 01-05-2020 04:29
Hi All,
I had the same cardio fitness was >44.0 excellent and dropped to 31.1 average. I deleted the exercises where I'd carried my phone durning a walk and it recorded an exercise as a run. it went back to my normal level. I think it must be to do the GPS function. Update. it was the recorded GPS activity that I deleted.
05-02-2020 23:40
05-02-2020 23:40
Mine is exactly the same since moving from Bkaze to Versa 2.. dropped 11 points over night..watch not measuring miles accurately either so speed low.. annoying when watch so expensive!?
07-01-2020 08:00
07-01-2020 08:00
I'm a little late to this thread but this is where my google search for the issue brought me so...
It's definitely the GPS as previously mentioned. I had a cardio score of 47 with a resting heart rate of 54. I used the GPS on a run and my cardio score dropped to 30, probably due to frequent stops since my dog is with me. I deleted the run from my app and my cardio popped back up to where it should be. I'll either not use GPS, which is really unnecessary running around my block a few times, or keep jogging in place while the dog does his thing.
Versa2 btw.
07-02-2020 02:27
07-02-2020 02:27
Hi, pleased I could help. Stay safe and jog on 😀
08-08-2020 12:20
08-08-2020 12:20
I had the same people of my cardio score dropping from good to poor in 2 days. I was shocked since I had recently started running up mountains and my heart rate is cardio majority of the way. I was confused since your score should get better with this type of exercise so once I’d deleted all of my gps exercises it bounced back so quickly.
Just shows how inaccurate the Fitbit is. I’m very annoyed it looks like this is a problem from the past two years. Fitbit you NEED to fix this
08-08-2020 12:35
08-08-2020 12:35
Mine was when I started using connected GPS
03-24-2021 03:08
03-24-2021 03:08
Hi there,
not sure if anyone has noticed but since wearing a mask at the gym my cardio fitness score went from 44 to 25? Has anyone else seen this or know how to fix it?
thank you
