01-27-2018 05:16
01-27-2018 05:16
Dear Fitbit, This morning I woke up and looked at my Ionic for the time and it was dead. I immediately hit the forums and tried different wall adapters, restart method, plug into pc as another user mentioned something about a battery gate issue. Nothing worked. A bit more persistence and time I tried yet another usb wall charger adapter and I got the circles of Ionic life and I was back in business.
My question to you is based on the many mentions on Ionic forums about this same issue, is this potentially a software fix in the making, or will this be an ongoing issue and I should send it back for a replacement now to avoid future frustrations? Aside from some music syncing issues I really enjoy the Ionic and had been promoting it in my office. I purchased mine on December 24th after much debate this vs. the Apple Watch. It has not been exposed to water and I use it for walking primarily.
Also, is it possible any of the third party apps, clockfaces could be causing the issue as I change the faces often- just a passing thought.
Thank you for your attention to this matter.
Best Answer01-27-2018 23:50
01-27-2018 23:50
I've had my Ionic since launch and haven't experienced the issue you described. I would be a bit cautious of it being a hardware issue. I guess all you can really do is see if it happens again, if it does though, I would definitely send it back as its not normal behaviour.
01-28-2018 03:36
01-28-2018 03:36
Thank you for your response. That was sort of where I was headed- wait and see. I am curious to see if this can be addressed via a software update. The first fitbit product I bought was terrible, the Flex I think - charger issue or battery, everyone I knew had the same issue and resulted in dead units within months. However my Charge HR2 despite not always wanting to sync when I needed it to, has been rock solid after a year of use.
Best Answer01-29-2018 18:19
01-29-2018 18:19
Update - a few days later, my Ionic is functioning as normal.
