Change air temperature from Celsius to Farenheight
How to change air temperature from Celsius to Fahrenheit under weather setting
1 REPLY 1
To change the units used for the temperature in the Weather app:
  1. In the Fitbit app, tap the Today tab User-added image > your profile picture > your device image > Apps.
  2. Tap the gear icon User-added image next to Weather. You may need to swipe up to find the app.
  3. In the Temperature Unit section, tap Units and choose the unit you want to use.
  4. Sync your device and then open the Weather app User-added image​ on your device to see the updated units.
