02-14-2018 15:40
02-14-2018 15:40
Hi everyone,
massive fan of fitbit but abit annoyed at my situation.
I used the fit bit charge 2 for 7 months and it tracked my fitness and heart rate from average to excellent - got to 62 heart score and never seemed to hit cardio or peak in heart rate ...
decided to upgrade to ionic and all of a sudden my score dropped to 59 and I’m spending all my time in cardio and peak yet nothing as changed?
Im wearing the ionic as per fitbit etc wore both devices together and both took about 5 mins to get similar readings...
Is my fitbit faulty or was my charge 2 at fault ...
02-14-2018 15:46
02-14-2018 15:46
@DeanoDeano1wrote:Hi everyone,
Hi @DeanoDeano1,
Can you provide more specific information? When you say heart score, are you referring to resting heart rate or cardio fitness score?
I'm having trouble understanding how a person could spend spend 0 time in the cardio zone. What kind of exercise are you doing?
I'm also having trouble understanding that the Ionic is putting you in cardio zone for 24 hours a day? Again, specifics would be helpful.
02-23-2018 12:37
02-23-2018 12:37
Hi , I mean cardio fitness score..
during jogs using my Charge 2 I was hitting mainly fat burn and cardio ( steady pace ) exact same using the ionic and I’m apparently hitting cardio and peak with readings of 203bpm...
Thanks
04-07-2018 08:19 - edited 04-07-2018 08:28
I upgraded to an iconic and I'm facing the same problem + when I move around and sit iconic stays in higher heart rate and takes much longer time to recover to normal heart rate than the charge 2. I'll compare it with heart stap heart monitor (while exercising) since its the most accurate and I'll post the results .
04-08-2018 05:42 - edited 04-09-2018 05:59
These readings where in the past 15 days (identical speed and time of workout،treadmill) :
Last 4 readings for cahrge2
Avrg 135.139.138.141
Max 147.148.154.162
Last 4 readings for iconic
Avrg 158.165.158.155
Max 169.190.189.173
I only monitor my 15min of joging with out 10min warning up or 10min cooling down since the charge2 use to spikes in warm up.
Know I took readings of polar chest strap vs iconic every 30 seconds :
Iconic . Polar
141. 118
150 . 121
152 . 126
159 . 131
159 . 136
157 . 138
158 . 144
161 . 142
158 . 144
154 . 147
157 . 147
161 . 151
168 . 153
165 . 157
164 . 159
157 . 154
159 . 157
162 . 157
159 . 157
166 . 153
166 . 161
164 . 160
166 .166
169 . 163
160 . 161
157 . 162
158 . 160
159 . 163
156 . 161
Average
159.37 Iconic
149.96 Polar
Max:
169 Iconic
166 Polar
It looks like I did make mistakes calculating the avrg, I did miss one reading though. Don't know what to get out of this!
04-09-2018 05:53 - edited 04-09-2018 06:25
I did another comparison today charge2 vs polar chest strap vs iconic.
Fixed speed, treadmill, 15 min, every 30 seconds for charge2 and polar, fitbit app calculations for iconic, warm up and cooling down monitoring excluded .
Charge2 . Polar
113 . 117
119 . 122
126 .129
130 . 134
134 . 135
135 . 138
138 . 141
140 . 143
141 . 144
135 . 147
142 . 147
147 . 149
142 . 151
141 . 150
140 . 152
141 . 153
139 . 154
139 . 155
138 . 156
136 . 155
156 . 153
156 . 156
145 . 157
146 . 158
157 . 158
157 . 157
154 . 157
152 . 159
147 . 157
153 . 156
Average
Charge2 142.3
Polar 148
Iconic 165
Max
Charge2 157
Polar 159
Iconic 191
This is messed up. So for constent speed joging it looks like the charge2 is more accurate. I won't post more tests but I'll give the Iconic a week or two, if it continues to be soo inaccurate I'll go back to charge2. Very disappointed!
04-09-2018 13:22
04-09-2018 13:22
@Khalaf Thanks for your help and also understand my issue.
I have gone from excellent fitness vo2 rating of 63 down to 54 since using my ionic , and I noticed when walking my heart rate is extremely high yet I have never felt fitter, I also noticed the charge 2 showing more realistic readings.. maybe a bug in the ionic but it is also putting me off wanting to use it... nothing more demotivating when you smash the record of your 7 mile run to it dropping another point in the fitness score !!
04-11-2018 04:58
04-11-2018 04:58
Good news today, I placed the Iconic one finger away from my wrist instead of two fingers for the charge2 + one tighter (I thought it was too tight but tryed anyway). I got average 144 bpm and max 163bpm! Which is what am used to seeing . Know If it continues that way I'll be happy, I'll post again in a week, please share if this works with you too.
04-16-2018 04:16
04-16-2018 04:16
Hi, thank you for the information, I tried this but still the same.
Today I got a 12 Lead ECG done from a friend who is a Cardiologist, my heart rate on 3 ECG readings were 42, 42 and 43bpm, and my Fitbit was showing 81bpm...
I am willing to trust a £2500 device compared to the Fitbit. I adjusted the watch to check position, and it has still not improved.
My Fitbit Charge 2 always showed 40 - 50bpm which would tie in with my ECG Reading...
Either a faulty Ionic device or a bug! when running I am not out of breath or totally exhausted, i feel at ease and enjoyable, yet my heart rate on the ionic says im peak 190 for more than 80% of the time... my charge 2 showed i never hit peak, just fat burn and may sometimes cardio...
May take this watch back...
04-19-2018 04:58 - edited 04-19-2018 05:05
It's been a week know and am prity back to normal heart rate numbers, 2 to 3 bpm higher than the charge2. I'm placing it less than a finger away from my wrist (like straight next to my wrist). I have a small wrist so I think the placment instructions don't apply for everyone
04-19-2018 05:04
04-19-2018 05:04
Motivation level gets bad when that happens. I thought I was tricked by the charge2!
11-12-2018 08:20
11-12-2018 08:20
My friend had that experience too. We made some amateur kind of research and finally, got to the opinion that Ionic's HR is more accurate than Charge 2. Maybe your Charge 2 was lying back there.
11-13-2018 12:36
11-13-2018 12:36
It's nice to see you in the community @sebastianshaw. Thank you for sharing your experience with us and that you got to the conclusion that Ionic's HR is more accurate than Charge 2.
You can check help article What should I know about my heart rate data?
Thank you for visiting the forums.
