10-05-2017 10:26 - last edited on 10-07-2017 16:16 by CarlosCFitbit
Has anyone had issues with the waterproofing on the Ionic? Someone commented on Facebook that they "heard" this was a problem from a reviewer friend. But, I've seen nothing on it.
Moderator edit: edited title for clarity
07-02-2018 14:30
07-02-2018 14:30
07-02-2018 14:39
07-02-2018 14:39
07-02-2018 16:23
07-02-2018 16:23
Thank you guys for the advice, I will return it and try my luck with a new one.
07-03-2018 12:42
07-03-2018 12:42
@robertreinink @txwoody @Rachael_Breen @DannoManno @Adama-B Thanks for sharing your experience on this thread regarding Ionic's screen condensation. I'm glad to read that a replacement was issued and that you are back on track. I'm sure this will be helpful for other users too.
@Abdallah79 Welcome to the Fitbit Community! I'm very glad to read that you found good advice on this thread on the Fitbit Community. I'm sure the new one will work perfectly for you.
Keep me posted!
07-03-2018 16:50
07-03-2018 16:50
07-04-2018 10:20
07-04-2018 10:20
@DannoManno Thanks for your reply and feedback! I'm a moderator at the Fitbit Community forums. If you need to talk to customer support, here is the link in which you can contact them, or let me know if you need me to create a case for you.
Sorry, I thought you were already back on track as your previous post stated that you tested your second device at the pool and shower over the week and so far so good.
Please let me know if you need further help and the issue you are experiencing with your new device and I will help you out with that.
Keep me posted!
07-06-2018 14:17
07-06-2018 14:17
Did you just end up buying a garmin?
07-06-2018 14:19
07-06-2018 14:19
Hi Rachael, I did. I've been a longtime fitbit customer/supporter, but this one really did push me over the edge. That, along with consistent issues with basic syncing, too many conversations with their support group, it made it very easy for me to switch. Been very pleased since, with no issues.
07-06-2018 14:24
07-06-2018 14:24
07-06-2018 14:27
07-06-2018 14:27
It does, battery life is good/comparable to fitbit.
07-06-2018 15:25
07-06-2018 15:25
I was told to get a garmin! But I really liked the Fitbit app, I had friends on there (I originally had a flex) I just wanted to be able to use it whilst I swam. I’m since to brave using it in the pool since the last time. I honestly think we should all be refunded due to the false advertising! As....had this not have said it was “waterproof” I would’ve switched to garmin! Gutted, it’ll be a long time before I can afford another one.
07-09-2018 17:17
07-09-2018 17:17
@Rachael_Breen Thanks for your reply and for your feedback. I'm glad you got a replacement unit.
Ionic is a waterproof device, so you should not experience any trouble again. I'd say try to use it at the pool, it should be fine.
@Abdallah79 @joeybrown105 Thanks for sharing your experience and help on this thread.
Keep me posted!
11-09-2018 00:00
11-09-2018 00:00
I understand your frustration, I’m still not happy with my ionic replacement, I’ve not attempted to go swimming with it on since I got it back and the swimproof feature was also the reason I upgraded to the ionic. Since getting a replacement I’ve noticed little splashes of water makes my ionic show the Fitbit icon on the screen, so I don’t trust that it would be capable of being swimproof! Once I can justify spending the money on a new watch I’ll be upgrading to a garmin!
11-09-2018 03:53
11-09-2018 03:53
11-12-2018 16:06
11-12-2018 16:06
@Rachael_Breen Thanks for your reply and for sharing the details about the situation you are experiencing with your replacement watch.
It shouldn't show that while swimming. Please note that you can use the email channel you had when you replaced Ionic the first time to report this scenario. You should get some help just like last time.
@txwoody I hope you're doing well! Thanks for sharing the experience you have had with your replacement watch. I'm really glad to read that your new watch has been working properly.
See you around!
12-25-2018 00:10
12-25-2018 00:10
I have the same problem. I went today for a swim and now my fitbit ionic has condensation behind the sensors, it shows 0% battery and it won’t take a new charge.
I had previous swims with this fitbit ionic and it was fine.
I’ve contacted the fitbit support and I’m waiting for their answer.
12-25-2018 11:17
12-25-2018 11:17
@Ciprian Welcome to the Fitbit forums! Thanks for posting the situation you have experienced with Ionic after swimming. It's unfortunate to read that it got some condensation and that the battery is not working properly.
Thanks for contacting customer support regarding this. I went ahead and contacted you via PM. Please keep an eye on your Community inbox.
Keep me posted!
01-11-2019 06:24
01-11-2019 06:24
01-11-2019 06:26
01-11-2019 06:26
I’ve not had anything like that, it my replacement sometimes shuts down and just displays the Fitbit logo, especially if it’s had a drop/splash of water on it....I wouldn’t trust it anywhere near a pool now, which is a shame as that feature was why I bought it.
01-24-2019 09:11 - edited 01-24-2019 09:14
Same issue here and they can't send a replacement to my country, I am truly sorry for wasting money on this company. They advertise their product as being waterproof but it took one shower to break the device. I really don't recommend buying Fitbit Ionic.
