04-06-2018 03:17
04-06-2018 03:17
Need to connect my phone to car Bluetooth but can only have one Bluetooth connected at a time. When you do this with any other device connected to you just press it and select disconnect but with ionic only option you get is forget this device can anyone help I really need my phone to connect to other devices but don’t want to forget device and then have to restart/load ionic every time I go out in car or use speakers etc thanks
Best Answer04-06-2018 07:32
04-06-2018 07:32
This shouldn’t be an issue @Prior10. I have my Ionic connected to my phone and my phone connected to my car by Bluetooth. They’re different BT protocols. The Ionic will use BT LE while the car will use classic. It would only be an issue if you were streaming music to the Ionic and then tried to connect to your car, which wouldn’t work (the one connection issue).
04-06-2018 05:01
04-06-2018 05:01
What phone? Android? iOS? Which bluetooth signal are you trying to "disconnect" from your phone? Have you turned off bluetooth on the watch?
Best Answer04-06-2018 05:19
04-06-2018 05:19
iOS - trying to disconnect ionic so I can use phone in car - Bluetooth of on watch (as far as I know)
Best Answer04-06-2018 05:29
04-06-2018 05:29
Hi @Prior10. Which iPhone model do you have?
Best Answer04-06-2018 05:59
04-06-2018 05:59
Pretty sure it’s 7 at the moment sorry about vagueness had it couple of yrs now but pretty sure
04-06-2018 07:32
04-06-2018 08:24
04-06-2018 08:24
Thanks for your help despite being turned of looks like trying to stream through watch it’s now working 🤞till next time 😂 thank you 🙏
