12-17-2018
19:17
11:39
HeydyF
12-17-2018
19:17
11:39
HeydyF
The last couple of days when I check my Ionic it shows charging status while on my wrist. I now notice that there appears to be some sort of corrosion around the battery charging connection. At first I thought it was just dirt but trying to clean it out I discovered that it's hard and affixed to the surface.
Anybody else have an issue like this ??
12-17-2018 22:28
12-17-2018 22:28
According to Fitbit cleaning tips - try rubbing the metal connectors with a soft toothbrush and rubbing alcohol. It should remove any unwanted buildup.
Best Answer12-19-2018 11:38
12-19-2018 11:38
Hey @SunsetRunner, welcome to the Community! I'd like to know if you have tried to clean the pins on both, the charging cable and the Ionic itself, as @SunsetRunner suggested, and if so, I'd like to know if your charging cable is charging fine or not.
Let me know how it goes!
Best Answer12-19-2018 18:11
12-19-2018 18:11
Hi HeydyFitbit,
It's is charging although it is a bit tricky since the charge cable wont go into the slot. I have to make sure it sitting just right to maintain contact.
I guess I needed to be more specific, I'm not looking for a solution to this issue. After talking to customer service it has been determined that the solution will be to replace the Ionic with a non Fitbit device.
I am just trying to determine if this is an isolated incident with my device, or if other users have had similar issues.
Best Answer04-22-2019 19:38
04-22-2019 19:38
Same problem. I’ve contacted customer service - let’s see how they do
