I have changed my credit card and I can't pay any more with the watch. I also can't access the walet. It either can't reister ionic with walet or can't connect to ionic on pin confirmation. I try reinstalling fitbit app and replace ionic device with no luck.
Any suggestions to fix the issue?
Best AnswerWelcome to the community @aroussekov
Let's see if I understand, where you able to get the new credit card installed on the Ionic?
Did you leave the old card attached out has it been removed?
As for the wallet, the easiest way to access it is to hold on the side button, then put in the pin. Normally there is no reason to have the actual wallet installed on the ionic, but some have had problems paying after the last update so this may have changed.
