04-08-2018
22:36
05:31
04-08-2018
22:36
05:31
My ionic not working after factory reset and only displaying “X data not cleared Sync & try again”
also after removing my ionic from Bluetooth and from mobile fitbit app, my iphone6 was unable to connect it back to Bluetooth and to the app.
04-09-2018 05:30
04-09-2018 05:30
Welcome to the Fitbit Community @Ankushsharma86! Thanks for letting me know what you've tried so far to solve the issue, nice way to go!
Well, this usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair your Ionic, forget Bluetooth (both Ionic and Ionic (Classic)) and perform the factory reset. To solve this issue follow these steps (some of them you already tried, but let's cover everything):
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
After making sure about that, try setting up your Ionic again.
Give this a go and let me know how it goes!
05-28-2018 04:11
05-28-2018 04:11
It does not work with any of the above. It basically come up straight after factory reset.
Best Answer05-28-2018 04:13
05-28-2018 04:13
It would let me sync again but it won’t finish the sync or update. It is really frustrating. I have tried restarting the iPhone, deleted the Fitbit app or tried with an iPad (made sure to disconnect other Bluetooth just in case someone asks if I’ve done that) etc. The fault lies in the watch. Not the phone.
Best Answer05-28-2018 06:30
05-28-2018 06:30
Welcome to the forums @Ktha! Thanks for trying the suggestions I posted here. ![]()
Since this sounds a bit more serious, I've created a Support Case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Best Answer05-28-2018 08:16
05-28-2018 08:16
I am having a similiar issue but with S9 plus. It's connected on the app but does not sync. Bluetooth error message
Best Answer07-06-2018 08:00
07-06-2018 08:00
I'm having same problem. How do I set up a support case?
Best Answer09-01-2018 15:31
09-01-2018 15:31
I have the same problem. Anyone can help me?
