05-10-2018 12:33 - edited 05-10-2018 12:34
Bought a newly released Huawei M5 MediaPad recently and long story short the Ionic will not stay synced (believe me I've spent hours trying!)
CS are telling me it's because it's not on the supported device list. Neither were the last 2 android tablets it ran perfectly on though. My question therefore is can the device actually make a difference if it is running the current version of Android or am I being fobbed off?
Best Answer05-10-2018 12:36
05-10-2018 12:36
Its always best to check the compatibility list before assuming it will work. Things change quickly and I sure its hard to keep up with all the new devices coming out.
I'm sure thy will get it added sometime
Compatibility list
https://www.fitbit.com/devices
Wendy | CA | Moto G6 Android
05-10-2018 12:41
05-10-2018 12:41
I do get that I just can't get my head around what difference the actual device makes when running the same version of Android?
The list is woefully out of date for many top manufacturers. This tablet was released 2 months ago so I'm not holding my breath! Lol
Best Answer05-10-2018 13:16
05-10-2018 13:33
05-10-2018 13:33
It worked fine for 2 days. Then nothing. Did the usual reset/ forget etc and hit a wall. Did a hard reset and it worked for 12 hours. Repeated numerous times over 5 days following all advice to the the letter. Every time I have to reset it stops syncing faster. Last night it was half an hour 😑
The watch works perfectly on my old iPad. The Huawei Is running Bluetooth 4.2
| Wireless | Wi-Fi: IEEE802.11a/b/g/n/ac; 2.4 GHz/ 5 GHz Bluetooth: 4.2, optional LTE |
Best Answer05-10-2018 13:43 - edited 05-10-2018 13:45
If it worked for a bit, I'm hopeful it can work again. I think there's so many tweaks that different phone manufacturers do on the OS level that Fitbit can only test so many. I do know there are people that have made things work with unsupported devices. The problem can be when future app or firmware updates break some functionality that initially worked on unsupported devices.
If I may ask, did you unpair the Ionic from your old tablets before loading the app on the new one, assuming the old ones are still around?
BTW, how do you like the tablet? It looks really nice.
05-10-2018 13:56
05-10-2018 13:56
I unpaired from all but the last because it bricked. Did a factory reset however and as I said it was fine for a good while.
Really loving the new tablet. It has the Apple quality feeling with the much better Android experience. Not cheap but not Apple £££. It's so good I've just bought my good lady one as well. Huawei are definitely moving up in the game👍
Best Answer05-10-2018 18:03
05-10-2018 18:03
Have you turned off other Bluetooth devices (or at least logged out of the Fitbit App)? Fitbit trackers can get pretty confused if multiple devices (computers, phones, or tablets) are trying to communicate with it at once.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
05-11-2018 02:16
05-11-2018 02:16
Sure have, no difference 😑
