02-21-2018
00:23
14:43
RicardoFitbit
02-21-2018
00:23
14:43
RicardoFitbit
hello my ionic is brand new & just out of the box and it doesn't detect heart rate . everything else seems to be working fine but this . The green led light does not appear to work at all . i have made sure that heart rate is switched to on ( and turned it off and on ) i have restarted it , re synced it and made sure its updated but still nothing i have seen that this is quite common problem upon some research into how i can fix this and i'm so disappointed because it looks like i have to send the item back as its faulty. This will take weeks to rectify and my partner and i were excited to start this journey together. Before i send it back could anybody suggest one more attempt i can make incase i may have missed something ? thanks in advance .
Best Answer02-21-2018 00:56
02-21-2018 00:56
Except wearing it on your wrist, I don't see anything else. HR sensor is disabled if not on your wrist.
But I am sure you tried that
Best Answer02-21-2018 07:47 - edited 02-21-2018 07:53
pistolaki, You could try a Factory Reset. Swipe left and touch Settings. Scroll down and touch About. Scroll down and touch Factory Reset. If that doesn't work, I would return it for exchange.
Best Answer01-12-2020 06:47
01-12-2020 06:47
Out of the box yesterday 11 Jan 2020. No LED. Spent hours trying to get to work and another hour+ with support. They are sending me a new one. Boy, do they test these before they ship them?
