04-02-2019
09:04
08:08
YojanaFitbit
04-02-2019
09:04
08:08
YojanaFitbit
I lost my charger a few weeks back, I got a new one yesterday and plugged it in. The screen showed 0% battery and then turned off. I couldn't get it to turn on but after googling I restarted it by holding down the left, and bottom right buttons. It booted up and was fully charged.
This morning I noticed it hadn't tracked my sleep, steps or heart rate. I restarted the device, factory reset it, updated the firmware, updated all apps, cleaned it with isopropanol, reinstalled the app and paired the device again with no luck. Some post here suggested switching to a Fitbit clockface or updating mine, I couldn't find an update so I switched to a Fitbit clockface. In between all of these steps, I checked if it had started tracking again. The top right button seems to be disabled as well. I can't say I used it much but I don't recall having problems with it before.
Everything is still the same. The device is nothing more than a bad smartwatch at this point, it doesn't track anything and I've tried everything I can think of. I had no issues before I lost my charger a few weeks back.
Moderator edit: Updated subject for clarity.
Best Answer04-03-2019 08:12
04-03-2019 08:12
Nice to see that you're digging into the Forums @halldor46.
Thanks for reaching out and for trying those steps to help your Ionic to track stats again. I think that it's best if you check with our support team what else you can try, since they have special tools to help you with this. I've requested already a case on your behalf. You should soon receive an email from customer support to the email you used to register with the Community Forums.
Please keep me posted!
Best Answer04-03-2019 10:51
04-03-2019 10:51
After the watch depleted its battery it won't charge. It's stuck in setup mode so I don't have access to the menu. Restarting it by holding the left and bottom right button doesn't work.
The screen displays the setup mode instructions, if I disconnect the charger it turns off in a few minutes, so there's obviously power coming from the charger.
