02-28-2018 08:48
02-28-2018 08:48
What is and how do u use these
123
456
7890
they seem to be on the screen when u press the left button
Best Answer02-28-2018 09:01
02-28-2018 09:01
That is the device lock, which happens every 24hrs or when you take off your Ionic. You will need to enter the code you set up either when installing Wallet or when you enabled Device Lock in your account settings
Best Answer02-28-2018 21:18
02-28-2018 21:18
It gets setup through the Fitbit app under the settings for the ionic.
