I would like to purchase a new tracker since I have been told that my Alta does not work and/or doesn't sync properly with my phone, an LG K20. Before I spend the $$$ on the newest thing, I would like to be sure it will work with my phone, otherwise, what is the point?!
Thank you!
@KBlanda wrote:I would like to purchase a new tracker since I have been told that my Alta does not work and/or doesn't sync properly with my phone, an LG K20. Before I spend the $$$ on the newest thing, I would like to be sure it will work with my phone, otherwise, what is the point?!
Thank you!
The LG K20 isn’t listed as a supported device, something I suspected given it wasn’t compatible with the Alta. Not good news, unfortunately.
Best Answer@KBlanda, adding to what @SunsetRunner said, usually (and I think with all recently issued Fitbits) if a phone isn't compatible with one Fitbit, it won't be compatible with others.
