08-28-2017 10:19 - last edited on 08-28-2017 12:42 by ErickFitbit
Does display on the Ionic stay on at all times or does is spend most of its time blacked out as with the Blaze?
Moderator edit: edited title for clarity
08-28-2017 11:41 - edited 08-28-2017 11:43
Yes. In the DC rainmaker video there are times the screen goes off and he has to wake it again. He pushes the button, but I assume it will also feature the quick view function too.
I have the Blaze and the raise wrist to view function is pretty decent. There are times when it does accidentally illuminate, but in general I find it to be very good.
08-28-2017 11:21
08-28-2017 11:21
As far as I can tell it' the same as the blaze. Raise your wrist to activate it.
08-28-2017 11:25
08-28-2017 11:25
Did you get that from one of the videos you watched? I ask because ll of the videos I've seen so far show the display illuminated full-time.
I've never used a Blaze; anybody have any comments about how intuitive the auto-illuminate function is?
08-28-2017 11:43
08-28-2017 11:43
@N8teGee wrote:Yes. In the DC rainmaker video there are times the screen goes off and he has to wake it again. He pushes the button, but I assume it will also feature the quick view function too.
Thanks much!
08-28-2017 12:42 - edited 08-28-2017 12:42
@shipo To conserve battery, the Ionic display turns off when not in use and can be turned back on by pressing the button or using our Quick View wrist gesture, as explained here.
I personally enjoy the feature and find it super convenient. Hope this helps to clarify!
08-28-2017 12:52
08-28-2017 12:52
@ErickFitbit wrote:@shipo To conserve battery, the Ionic display turns off when not in use and can be turned back on by pressing the button or using our Quick View wrist gesture, as explained here.
Thanks, I guess I'm just spoiled by the always-on mode of the Surge.
08-29-2017 11:29
08-29-2017 11:29
I'm in the medical field and I need the seconds on the display to stay illuminated for longer than 3 seconds. Ideally, it needs to stay illuminated for 10-15 seconds so I can calculate pulse & respiratory rate in my patients. I'm just curious if they have finally added this feature with the ionic.
08-29-2017 11:36 - last edited on 08-31-2017 04:57 by MarreFitbit
I understand the Iconic will be like the Blaze and not like the Surge. Please reconsider or make an option for always on. I like a watch that is always on, but don't want two devices. I have enjoyed my surges for the past couple of years. I would live to upgrade to Iconic, but not at the expense of a "watch" that's always on.
Thanks for the consideration.
Moderator edit: updated for clarity
08-30-2017 06:10
08-30-2017 06:10
I'm in the same boat, I like the fact my Surge is always on; that said, I'm upgrading to the Ionic; hopefully the auto-on feature is intuitive enough to make me not regret the upgrade.
08-30-2017 08:59
08-30-2017 08:59
I have the Charge 2 and the auto off display is annoying when at the gym. it
might sound painless to lift your wrist or push a button but the reality is it gets very tedious in my opinion. I use the workout and weights function as well as the stopwatch and sometimes you just want to glance down and it be on. I know it's a battery life trade off but an option to override when in workout mode would be better. For that reason I'm not upgrading to the Ionic. Shame because it looks cool.
08-30-2017 09:08
08-30-2017 09:08
@Aibonator Thanks for your feedback. I recommend creating an Ionic specific Feature Suggestion idea and making sure to vote for it. Once you've created that, please share it here so others who are interested may vote on it as well. Thanks again for the feedback, I will make sure to relay it to our product development team.
08-30-2017 10:35 - last edited on 08-31-2017 14:20 by ErickFitbit
I'm not sure of the demographic they are shooting for with the Iconic, but I have to feel that there are a lot of 50 year olds that grew up with watches, but are interested in staying in shape and keeping up with technology somewhat as well. Having a device that does all these things well has made the Surge the #1 rated device by many, like Consumer Reports, for two years running. Amazing for a technology with so much competition! I suspect there are a lot more 50 year olds willing and able to pay $300 for a device than 20 year olds that don't really care as much about the always on. It certainly seems like something that should be able to be made a software option on the device. If it meant charging every day, I could certainly live with that. I would just want it to last one whole day.
Moderator edit: format
08-30-2017 11:01
08-30-2017 11:01
@shipo wrote:I guess I'm just spoiled by the always-on mode of the Surge.
@shipo: Trade-off between monochrome/relatively dim/lower res. display of Surge and color/brighter/higher res. display of Blaze/Ionic.
Dominique | Finland
08-30-2017 11:05
08-30-2017 11:05
Yup, I'm well aware of the differences; personally I'd opt for an always on non-color display. Failing that, I'd opt for a dim always on display which can brighten as the Surge does at the expense of some battery life.
08-30-2017 12:55
08-30-2017 12:55
Well, speaking as a 50+ user, currently using an AW but previously had a Blaze, I'm more than at ease with auto-on as a means of viewing my watch. The only down side is at night, when I have to disable it. I'm not envisaging any problem with the Ionic in this respect.
08-30-2017 19:18
08-30-2017 19:18
Well, speaking as a 70+ user, I am perfectly happy with the auto-on feature, and have no desire for the display to be on all of the time. Since the Ionic will have the feature to disable the Quick View when desired, and then re-enable it when desired, this will correct the problem of it coming on when sleeping as well. I'm looking forward to being able to put the Ionic through its paces!
08-31-2017 13:46
08-31-2017 13:46
@shipo the Surge and Ionic have entirely different technologies when it comes to sisplays. The Surge uses LCD and has no illumination by itsrlf. Tgats why it can stay on and why it has a backup light that activated with Quick View.
The Ionic can only be read when the display is illuminated, and uses a lot more power.
08-31-2017 14:38
08-31-2017 14:38
Hi everyone -- I merged a thread asking about keeping the Ionic display ON for workouts here. If you've just joined this thread via my merge, I recommend checking out my latest response here. Thanks for your feedback and I am looking forward to seeing your Ionic specific Feature Suggestion in this thread.
09-14-2017 17:57
09-14-2017 17:57
I regret moving to the Charge 2. The always on display was terrific, and the the Charge 2's display means I still have to wear a watch. I carry the charge in my purse.
